Dans le Manuel de Service il existe une procédure PIWIS plus fiable que le check visuel avec l'ordinateur de bord pour tester le niveau d'huile moteur. Elle a l'avantage de donner le volume à rajouter pour être au max.
La voici:
WM 170101 CHECKING ENGINE-OIL LEVEL USING THE PIWIS TESTER (CAYENNE,
CAYENNE GTS, CAYENNE S HYBRID, CAYENNE S E, CAYENNE TURBO, CAYENNE
(3.0)) > CHECKING ENGINE-OIL LEVEL
nformation
The PIWIS Tester II 9818 instructions take precedence and in the event of a discrepancy these are the
instructions that must be followed. Deviations may occur with later software versions.
1. PIWIS Tester II 9818 must be connected and ignition switched on.
2. Start the diagnostic program and select the required vehicle.
3. Select the DME control unit in the control unit overview. Press [F12] to continue.
4. Select the Maintenance/repairs menu. Press [F12] to continue.
5. Select the Oil filling function. Press [F12] to continue.
Information
Requirements for oil level measurement using the PIWIS Tester:
1. Engine running at idle speed
2. The engine oil temperature (T030) is 90 °C
3. The vehicle is horizontal on a level surface
6. Start the engine and let it run until an engine oil temperature of 90° C is reached.
Rev the engine if necessary to heat the engine oil to the specified temperature.
7.The oil level measurement process starts automatically as soon as the engine oil temperature
8. Switch off engine.
9. Add the quantity of oil displayed on the PIWIS Tester II 9818 .
10. Disconnect the PIWIS Tester.
Voila ce que ça donne sur mon diag X431 V+ pro:
Test en cours:
Résultat:
Des trucs et des conseils pratique pour votre Cayenne, c'est ici.
